Harness routing to the front lights
Patton
I'm trying to figure out the correct way to route the wiring as it goes from the flasher relay to the front of the car with the lights and the horns. My original harness was so hacked up it was impractical to use as a guide.
What is the correct way to route it? Here is a a picture for illustration.
Choice A - Up above the heater tube, running over the inner fender coming out behind the left headlamp
Choice B - Under the heater tube, running along the inner fender coming through next to the steering box and radiator
Choice C - I have it so wrong that its pbvious that I am clueless /ubbthreads/images/graemlins/smile.gif
As you see, I have it with choice A right now, but it seems like the connectors are a little short.
Thanks, after this, I have to put a grommet for the battery cable into the truck, and the harness is all routed and clipped in. Plus I just finished putting all of the gauges back into the dash.
Thanks
Patton
Hi Patton, most of the ones I remember seeing used your option "B"---Fwiw---Keoke
