Hardware for Parrish hardtop
2
2Triumphs
Just purchased a fiberglass top. Said it was new, however I am not sure if I have all of the hardware. I just can't figure out how it connects to the top of the windshield. Can anyone help with this problem?
Thanks
I'm assuming this is a TR6.
If so, and it's anything like the steel factory top, then there should be a rubber grommet on top of the windshield frame. Once you take those off, the hole should go all the way though to the underside of the frame. The factory top has bolts that go through these holes and is secured from the bottom.
I have the bolts, however is the hole threaded in order to hold these bolts? I have nothing in the top to attach the bolts to.. 74 tr6
On the right side you will see the hardware that secures the top to the windshield. Be sure you have part 34, a stand off inserted from the top that prevents the bolt (part 31) from collapsing the windshield frame.
