Healey Nut
Hi Guest!
If you look at Healeyblue's pic you will see the second layer of rubber that is glued to the hardtop before you attach rubber with the ciips.
For sure there will be many test fits as is typical when rebuilding these old girlsHealey nut, test fit the double flat pieces and final seal. You may find if you add to many layers of rubber around the back that the sides of the hardtop will not sit on the cockpit railings behind the doors.
