justin_mercier said:That's not making it 'wrong' that's just a different style surrey top backlight.
JerryVV said:The Finisher pieces refered to above as 25 and 26 in the moss cataloge are simply pieces of steel sheet stock cut to the outline of the post or upright portion of the backlight frame....
A trim shop can make these, cover them and fit them well for you if installing an original backlight. These pieces are not required on the fiberglass backlights I've seen as the posts are solid and painted.
JerryVV said:The Finisher pieces refered to above as 25 and 26 in the moss cataloge are simply pieces of steel sheet stock cut to the outline of the post or upright portion of the backlight frame. On an orginal backlight the post has a open space in the casting that needs to be trimmed out. The finisher is covered in a vinyl using the same color as the headliner, white as original. There is a small screw that holds the bottom on to the backlight at the lower inner corner of the finisher. By inner I mean towards the door. The finisher is then forced behind the fuzzy seal to hold it flush top to bottom. The rear edge of the finisher should be captured by the window rubber seal. Mine don't fit worth crap! I need to drill and tap a hole into the backlight frame for some additional screws.
TonyPanchot said:My Frame is identical to rlich's frame
i did not know of alts
kind of blindly bought fg top and rear frame
guess i got lucky as they fit up very nicely
just dropped off for paint
attempting to be ready for STL all Brit in Sept.
come on glass don't get held in customs
Challenge to rlich,
Bring that puppy to STL All Brit, I could use some competition
PS That challenge is open to Everybody, Just thought it would be cool to see
2 Surrey's on the field
