Brosky
Hardtop Carrier Update
I had to make an adjustment to the carrier so that someone else doesn't make the same mistake that I did where the top rests. Fortunately an easily fixable issue for the rack, but not so easy for the two little marks on the top.
This is the needed correction, if you followed MY pictures and added extra panels to Shawn's original design, (which is fine without them), as long as the side rails are stable and secured well.
As long as the outer panels shown on mine, are mounted on the INSIDE instead, all is well. The pictures at the beginning and end clearly show what to do. Or in this case, not to do....Dumb, dumb, dumb on my part!!
Hardtop Carrier, with Modifications to original pictures
