I bought a hard top a while back for my bugeye. I am still not sure if I will keep it. I normally don't like hard tops, but the bugeye top seems to fit well with the style of the car. After searching a long time, I found one that did not have the typical damage. The only problem with this one is the inside "paint" is flaking off. On the inside roof, most of it has a rough surface. There is no separation on any smooth surface on the top or inside. I used a pressure washer to knock off anything remotely loose. My questions are 1)What is the material that is coming off? Is it just paint or gel coat? 2) If it is gel coat, how easy is this to redo? 3)Would I need to take out the rear window to do this? 4) What would insure better adhesion when I redo the inside? (I would include a picture, but I can't figure out how to add it to my post.) Any help would greatly be appreciated.
Kevin
Kevin
Hi Guest!
