KVH
An old subject, sorry, but I can't solve it. Engine starts fine cold, and runs great, but won't start hot unless I wait 20 minutes.
I've tried everything. New points, floats, fuel pump, coil, timing. Still won't start from "hot" unless I let it sit.
So, here I go again: a) could it be the low tension wire from the coil to the distributor? What is low tension anyway? Mine is just a 16 gauge insulated wire;
b) could it be the condenser? I'm sure I already replaced it, but I could try again I suppose;
c) what about the distributor cap and wires? Should I replace those as well?
d) I replaced the plugs. Do I try that again?
e) my "new" coil has oil on the underside. I can't imagine that's the problem since when it was new 8 months ago there was no improvement in hot starting;
f) I checked the fuel level in the jets; it looked fine.
Something is just a total mystery. Any more ideas?
Hi Guest!
