twas_brillig
Dang! just composed a comment worthy of Shakespeare, and the modern equivalent of The Prince of Darkness wiped it out!
Try again:
1 - our 'running' Sprite is on 155/80R13 Kumho tires. I think I mentioned 165 earlier; I'm assuming the the 155s are about the widest you'd want to go on a stock rim
2- I went out and measured up a Rostyle wheel that we'd salvaged years ago from a Midget of unknown vintage (if you need decent front fenders, holler with a PM as the shop in Edmonton, Alberta, that I gave them to still has them hanging on a wall). The wheel is 5 3/8 inches from outer width to outer width; the mounting flange is inset 3 5/8" inches from the inner 'outer' edge of the wheel
3- the Rostyle weighs about 7.5 pounds,which is about 2 pounds heavier than the original BE wheel
Doug
Try again:
Doug
