Looking at the handbrake cable adjustment in the tunnel. I think it may be in wrong. There is a bracket the cable passes through. The installation is from rear going forward is
barrel - bracket - nut. looks like =l: The bracket is clamped tight between the barrel and the nut. I'm thinking it should be barrel - nut - tab. Like =:l so that backing off the nut pushes the barrel and cable housing back. But if installed this way, it seems the nut could back off by itself. Should there be two nuts?
Looks like it has been this way for ever.
It has never been 3 clicks.
I'm all out of adjustment on the rear wheel angle adjuster. Brake shoes are adjusted spot on.
Oh for a picture.
Oh for a picture.
