TimK
I have the tunnel off to replace OD solenoid and install new Heritage carpets. The handbrake assembly is not fastened to the frame. There is an "L" shaped thick metal bracket that looks like it should be welded to the frame, but it is loose. When I lift the handbrake handle, the whole assembly moves up until it hits the sheet metal of the tunnel extension. I cannot see any way to fasten it other than welding (which I do not have the equipment or expertise to do). Any advice would be appreciated as usual...
