TR2/3/3A Hand crank misalignment
Got_All_4
Went to try my newly purchased hand crank and when I put it through the hole in the radiator it didn't hook up to the crank shaft bolt. Looking through and aligning the 2 holes I can see that the engine crank isn't in line with the hole in the radiator. Do I need to shim it over and up a bit. About over a 1/2" and up 5/16". Or what?
TR3driver
Great Pumpkin - R.I.P
That's apparently what the factory did, the shims are P/N 109582 used "as required".
But I would suggest changing the motor mounts first. They do sag with age, sometimes quite a bit.
Got_All_4
Got_All_4
I suppose they could have sagged a bit but it's only been 2 years since I put new ones in. I may have only put 1 shim on top as I didn't have a hand crank then and not thinking about alingment. Now the shims would raise the engine but what about right to left?
DavidApp
Had the same problem a few weeks ago.
I ended up lifting the motor and removing the mount bolts in the frame. Then shifting the engine sideways and up to align the holes. Noted where the bolt holes were and filed one mount holes to get them to line up.
Hanging the motor from a hoist worked better tha a jack as there is some wobble.
Lines up great now with the extra shims and the sideways mover.
David
Geo Hahn
...Do I need to shim it over and up a bit. About over a 1/2" and up 5/16". Or what?
I had to shim a bit when I got the radiator re-cored but not as much as you describe -- that may be a challenge.
One issue you will encounter is that this is going the throw off the alignment of the thermostat housing and top radiator connection. Ideally those should be in line - some tolerance is offered by the accordion hose, hopefully that will accommodate the change.
Is the side-to-side ½" misalignment clearly the engine or could the radiator or guide be shifted at all?
DavidApp
When lowering the motor/gearbox assembly onto the frame there seems to be some wiggle room side to side and it only becomes a problem when you try to align the radiator hole and of course the thermostat hose connection.
I noticed the crank misalignment before I attempted to do the hose connection. When I got the crank hole right the hose connection was good as well.
David
TR3driver
I've not had a problem with motor mounts (don't even have a hole in the radiator); but I've certainly had other rubber aftermarket parts that fell apart in less than 2 years.
If worst comes to worst, you may have to chase down which parts are bent (frame, engine front plate, etc) and either bend them back or replace them.
There may also be some wiggle room in the radiator location; especially if you use Bob Schaller's modification
https://drive.google.com/open?id=0B2H2NJt34OffMmE1YTU0YzctMTQyOC00MmJmLWFiZGItNTI5ZjI3N2NjZTIy
DavidApp
Hopefully everything will still be in line when the front cowl goes on and the guide is in place.
I always had problems with the guide moving on my old TR2 in England. That one had a fiberglass cowl and I did not realize how much the cowl supports the guide. The rods only do so much to position it.
David
CJD
Right to left is controlled by using different number of shims left side or right as necessary. Because they are on an acute angle, a thin shim makes a much larger change at the crank. In general add shims to center the crank first. Once centered, then add equal to both sides to lift the front as necessary.
K For Sale Starter Hand Crank Triumph Classifieds 0
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
G MGB Hand turning the crank MG 7
H TR2/3/3A Triumph TR3 Hand crank alignment Triumph 21
boxfullofyertoys Crank super hard to rotate by hand Spridgets 29
T TR2/3/3A TR3 starting with hand crank? Triumph 26
CraigLandrum Manual Hand Crank Guide mounting? Triumph 4
tahoe healey Hand crank Austin Healey 12
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 0
S Routing of Hand Brake Cable Austin Healey 6
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
B MGA Hand brake handle disassembly MG 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
M Hand Brake Adjustment Spridgets 11
Boink Left-hand Drive E-type at Windsor Jaguar 5
H weird things painted by hand with a brush Austin Healey 6
Michael Oritt Hand brake adjustment Austin Healey 8
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Simmo TR6 Right Hand Drive conversion Triumph 5
D 69 E-Type sputters when making left hand turn Jaguar 6
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
B BN2 First right hand drive model car number 16 Austin Healey 4
Tinkerman TR2/3/3A TR 3A Hand Brake Trim Out Triumph 4
PatGalvin TR2/3/3A Hand Brake Lever Fork Triumph 7
B TR6 Right Hand Drive????? Triumph 8
Jer "banning" of right hand drive cars being discussed in this province... Spridgets 12
JPSmit Wiring Key - hand to have Restoration & Tools 1
TomMull TR2/3/3A Hand starting Triumph 12
S Right Hand Drive Spridgets 7
M Right Hand Drive cable routing Spridgets 11
Lukens Turning motor over by hand? Triumph 22
NutmegCT hand grip straps Restoration & Tools 2
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
M Hand/foot pump for tire inflation Triumph 15
K Second hand spoked rims Triumph 18
B TR2/3/3A TR3. Would you put it back to right hand drive? Triumph 11
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
J Hand brake rod, twisted? Spridgets 3
T Streched hand brake cable? Spridgets 18
middie Engine stiff to hand turn Spridgets 22
M Rotating the crankshaft by hand Triumph 35
PAUL161 MGB-GT Right Hand Drive Conversion--MG-GT MG 12
