Though I have followed the shop manual and set the rear brakes up hard and then adjusted the length of the hand brake cable my removing the clevis and screwing the forked terminal in, the handbrake simply will not set up hard enough to prevent the car from rolling on even a gradual slope. I suspect that the cable has simply become to "stretchy", to coin a word.
Moss sells the handbrake cable as a separate piece but I don't see how I am going to access the end that attaches to the lever actuator in the cockpit. Must I remove the propellor shaft--or worse--in order to remove and replace the cable on its front end?
