Half capacity of the fuel tank
SD Bugeye
I’m having fueling issue
ive discovered that the pickup tube in the tank draws air when tank reaches approx 3 gallons from full.
what is on that pickup?
the fitting is out the side wall of the tank facing the front of the car.
im concedering drilling it thru and putting a tube turned down toward bottom of tank passing thru the fitting with a crush seal..
there does seem to be anything moving around in the tank
anybody know what the situation is on that side of the tank is there a screen could I have knock off the pickup tube with my ... sprited driving?
bobhustead
Seems like there may be an opening (corrosion pit) in the pickup line at the level equivalent to 3 gallons down. Replacing the pickup top to bottom seems like the solution.
SD Bugeye
SD Bugeye
Oh there is a leak fuel pump gets pissy when it gets down there I’m just tired of only have about 80 mile range.
think when it get cool this fall I’m going in!
just wish I knew what the setup was so I can conjure a plan.
nomad
If you remove the sending unit perhaps you can see the problem.
I have some junker tanks but they are later ones.
nomad
If you get down to the southeast part of the state I'll give you one or I may be up in the Mitchell area sometime before fall. Definitely be there for pheasant season.
Kurt
SD Bugeye
SD Bugeye
Thanks for the offer Kurt
i really don’t want to lay her up,in the middle of summer
so a fall plan may be the answer
I’ll keep,you in on what I decide
im going to have to make a big iced tea and spend some time under there and see what’s up
did I mention it’s hot out ?
JPSmit
can you slide a new longer tube down through the old and seal it?
SD Bugeye
SD Bugeye
Maybe but would like to know what is in the tank
if it is a tube that bends down on a curve I think so
if it’s off at an angle then I gain nothing
this was a new tank back in 04 but heck who knows how it was constructed
twas_brillig
A story I heard from a local shop, years ago, about a mini: owner basically had no range. He'd run out of gas, fill it, the tank wouldn't take much, and it would run dry again. I don't remember details but I think it had been parked for some years and he had one or two small children who played in and around it.
The shop pulled the tank and **** near collapsed the guy who was removing it, as it was horrendously heavy. The phone call to the owner went something like:
"Do you have some decorative red stone along your driveway?"
"Yes."
"Was it parked with the gas cap off, and do you have kids?
"Yes."
Doug
Got_All_4 TR5/TR250 Only half of the tack is lit Triumph 14
F TR2/3/3A back half to chassis questions Triumph 105
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B BJ8 Half-Shaft Oil Seal Austin Healey 5
tahoe healey half car cover Austin Healey 3
D Front suspension half moon cotters Austin Healey 6
J Half round tube or D tube source ?? Restoration & Tools 2
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
Jim_Gruber Looking for back half of PS Floorpan for my BE Spridgets 6
S TR2/3/3A Well onto the second half Triumph 2
Boggsy64 MGB Half shaft question MG 2
H brake calliper half seal size Austin Healey 4
Bremer TR2/3/3A TR3 half doors Triumph 11
G Half shaft removal Triumph 3
Jim_Gruber Progress - Suspension half done yeah! Spridgets 2
Brian_James Wire wheel half shafts and bare 1275 block Houston Spridgets 1
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
hondo402000 new CV half shafts Triumph 49
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
ScottTR6 Half shaft replacement Spridgets 7
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
T Half way? Triumph 189
tweety Changing a half axle Spridgets 1
S I hope my car looks HALF as good as this one...... Jaguar 6
jvandyke weird half top, soft targa? Spridgets 10
mrv8q TR6 TR6 half-shaft removal Triumph 15
B 3.9 Diff/half shaft/spline question. MG 2
J Spitfire Spitfire Half shafts Triumph 3
F Removing Axle Half Shaft [Tube Type] MG 4
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
JPSmit Help #3 - diff + half shafts now Spridgets 2
G Ninety nine and a half just won't do.... Triumph 15
drooartz Tips for brake drum/diff/half shaft removal Spridgets 14
G Flag at Half Mast for a While at AAW Triumph 6
Z Axle half shafts Austin Healey 0
GB1 Half Shafts - Hardened Spridgets 18
A Introduction [half a day late] Triumph 6
bighly Dream Machines in Half Moon Bay CA Austin Healey 1
martyc Help! Stupid Half-Tonneau Question MG 3
J TR6 TR6 - half top/bikini top? Triumph 1
D Stag Stag half shaft removal Triumph 6
TypeRboy Half way there.. Lotus 1
Basil Half-axel U-joints - HELP! Jaguar 6
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
B Midget Differential Capacity Spridgets 5
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
S Large capacity fuel tank Spridgets 1
