Wedge Halelujah TR7
Dale
Hello everybody!
Well, after 6 months and much procrastination,(nothing slows the senses like fear of discovering the worst) I got a new timing chain installed and the valves adjusted and have eliminated the nasty knock that prompted me to park it. I am looking forward to many topless adventures and daily drives to work when the weather is too wet to scooter.
BTW the things will run on two cylinders if you put the plug wires on in reverse order. The book says the rotor turns anti-clockwise, but who would bother to check it when it's only been 6 months since who took the plug wires and the distributor cap off. Anyway, I wanted to share my elation at not having a rod or main bearing knocking and that my friend that said it sounded more like top end was correct. I suppose that adjusting the timing chain would have accomplished the same, but if you've got the timing cover off it seems just as well to replace the chain.
I had picked up an odd lot of valve adjustment shims off E-Bay and was sure I wouldn't have any I needed, but again I lucked out and had more than enough of the requisit ones. Only one valve did not need reshimming, all the rest had tightened up and needed thinner shims.
Thanks for the rep Jeff. It is good to get back on, though I'm not able to spend the time I'd like. Drove it to work Monday, I still enjoy answering the inevitable questions ie Who makes Triumph? etc. I'm working with a lot of fine folks that are half my age and it is so true that ones historical perspective is based on when you're born. With my 7 they seem to think it's newer than it is, might say something for the timelessness of Harris Mann's design, though I don't think it's in a league with the Avanti. Take Care All
Feels good, doesn't it? /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
And you're absolutely right about the design of these cars. Still amazes me that they're selling so cheaply. Get one while you can. Even if they DON'T increase in value, the fun factor is a great return on investment!
