Sounds like you should be talking to the company you bought them from. If they are not what you ordered and do not fit, they should replace with the correct parts.No. The carbs on the car were clearly Stromberg CD 2-SEs and the screws that worked were clearly SU screws (5-40 with split end). Throttle plates were correct, though. Just wondering if this was some sort of common swap.
'There are ZS throttle shafts that require a different screw....one and the most common and probably original is a flat head with a split at the tip of the threads to be spread as lock/..the other which I believe must belong to a replacement shaft because I see it so rarely is a rounded head, no split tip to lock so a thread locker is used.
When I go into the shop later today, I'll get pictures.
