H6 carbs
spritenut
Being a Sprite guy, I do know a little about SUs but I just acquired a few boxes of old Jaguar bits. None of which will fit my 03 S Type :wink:
I have a pair of carbs, the early ones 1.75" type H.
I also have 2 intake manifolds and a few fuel system fittings.
One of the intakes has a water tube and a temp sensor in it, the other looks earlier.
I was told by the Sprite owner that he thought the parts were from an XK 120 but he was not sure.
All the parts will be going on Ebay unless anyone from this forum wants to make any offer and save me the Ebay trouble.
The carbs are clean, I disassembled them and cleaned every bit separate. Pistons work perfect, throttle shafts are very good, and the float needles even work. There are parts missing, banjo bolts, throttle links, screws for the dash pots, and who knows what else.
I also have a box of what appears to be internal engine and some suspension bolts, bits, and brackets.
Email me for more particulars Frank <spritenut@comcast.net>
Don't forget, the Jag carbs have the Mercurochrome in then.
