hondo402000
When I put my car back together after the paint job, the head lights were dim on low, I thought I had a bad ground but doing some investigating, I think I have the ground on the wrong terminal, I found a wiring diagram for the H4 bulbs
so FWIW looking at the connectors, if the diagram doesnt post correctly top terminal is low
left terminal is ground right terminal is high beam
.. low
.... _
gr | | high
so I will check when I get home
might have been wired wrong since I installed them
oops
Hondo
.. low
.... _
gr | | high
oops
Hondo
