My Bugeye shop manual lists the carbs for my car as type H1 (it actually says HI--an obvious misprint, but it leaves me wondering what other errors might have been made). My Haynes manual says it has type HS1. From the figures in the little blue book on SU carb tuning, it appears that I do have H1 carbs, and it isn't clear that an HS1 even exists.
So....the question: first, am I correct in my conclusion that I have an H1 carb on a stock, 1960 bugeye? Second, is there really a type HS1 carburetor? Or are frequent references to it just an error, since the later cars use HS type carbs? Finally, if the HS1 does indeed exist, was it used on any sprites?
