Gunk in the water passages
tdskip
So I manage to pull the MGA engine myself today. It wasn't quick, and it sure wasn't pretty, but the engine and transmission are out without and damage or newly required body work. (and I have all my fingers and toes still).
I knew I was going to need a new radiator, but this junk in the waterway near the water pump has me nervous. It was probably 1/3 constricted before I went after it with the screw driver.
Does she just need a good flushing? I hope my arteries don't look like that.
tony barnhill
Great Pumpkin - R.I.P
Serious backflush - maybe even deeptanking!
Looks like somebody has used some type stopleak in it!
PAUL161
Tony, am I looking at the fan blade wrong? Looks like it's on backwards. ???
Platinum
Yup. "Cup" should be engine-ward.
tony barnhill
Didn't even look at it - I was busy with the gunk...Doc said it!
T
tdskip
Holy cow - good catch guys.
For the record - I didn't assemble that I bought it that way! LOL.
tony barnhill
No, flip your fan over.
RickB
It's the eternal fan question - to suck or to blow.
You definitely want it to suck air through the radiator, not blow it against the oncoming air as you drive forward.
Tony & the rest are correct.
From the drawing if you look at the top shaded fan blade, then look at the next shaded blade from the top you can definitely see the curve is cupped towards the motor.
3D perspective can be a tricky thing in drawing.
jlaird
And you put that nice clean screw driver in that nasty stuff, shame on you. hehe.
Guinn
Uh, Rick. I don't believe that turning the fan backwards will blow instead of suck. Unless you also turn the engine backwards. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
But it won't be as efficient.
Guinn
Steve_S
LOL! I didn't even notice the fan. Guinn is correct, the fan will not reverse the direction of air flow unless the direction of the fan itself it reversed. A backwards fan will simply pull less air than one mounted in the proper direction.
Deleted member 3577
I bought a block last year and spent about an hour cleaning out the drain passageway with a coat hanger...
(It wouldn't drain)
Couldn't believe how much crud was in there.
(And that was AFTER hot tanking it)
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
M What's the best way to clean off under-gunk? Spridgets 10
Nunyas recommendations for cleaning out carb gunk... MG 16
Michael Oritt Water Pump Recommendations Austin Healey 1
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
M 1500 Midget water pump weep hole Spridgets 2
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
KVH General Tech Water Pump Triumph 3
D Water Valve Connection Austin Healey 4
T TR2/3/3A Moss uprated water pump Triumph 6
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A Water pumps/head cooling Triumph 22
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Aussiea40 A40 water pump British Motor Corp 7
A MGB Stuck water temperature sensor MG 26
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
AngliaGT Water Pump Recommendations? Other Cars 2
shadowfever Water temp Spridgets 9
nevets Water Pump Installation Austin Healey 9
drooartz Hose from water pump to head, remove water pump? Spridgets 12
nevets Water Pump Removal Austin Healey 6
C TR2/3/3A Water pump issue Triumph 8
Lin Heater water valve question Spridgets 2
Editor_Reid Water Temp Gauge Austin Healey 5
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Water pump Austin Healey 5
Patrick67BJ8 Water filters Austin Healey 16
George Zeck Water Pump ? Spridgets 5
F New water pumps on the market Austin Healey 25
nichola TR6 Resurrecting a water pump, worth it? Triumph 7
D TR2/3/3A extra hole in my water pump? Triumph 3
C Water flow in heater? Austin Healey 5
JPSmit water pump installation Spridgets 6
Michael Oritt Water Pump Leak Austin Healey 41
Kleykamp TR2/3/3A Water pump gasket sealant??? Triumph 5
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S TR2/3/3A tap water will no antifreeze on new engine Triumph 2
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
dklawson New [to me] Compressor - Water & Auto Drains Restoration & Tools 14
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
F Removing oil and water guage from BT7 dash Austin Healey 17
K For Sale Triumph TR3 Water Pumps for Rebuild Triumph Classifieds 0
D TR2/3/3A TR3 water pump question Triumph 4
