Hi guys - this is a cross post but since it applies to TR4a IRS cars I though it might be useful to post here as well. <span style="text-decoration: underline">Please feel free to correct or suggest improvements as this was my first time going this</span>!
Thanks to Bob Danielson for his site documentation, which is located here https://tr6.danielsonfamily.org/TrailingArmBushings.htm .
OK, let's get started. First, test fit the bush by gently knocking it into place with a hammer. This one isn't quite all the way in yet;
Next, insert the steel inner sleeve into the bush and see if it can be pushed into the bush;
Chances are pretty good that it won't be able to so you'll need to hone the trailing arm to get a proper fit. This is a bit of a trial and error process so you just have to hone, test fit, and then hone again if it doesn't slide in (with some real pushing)
You'll likely need to use a socket and hammer to press against the bush during the test fitting process;
<span style="font-weight: bold">Only</span> once the inner sleeve can be inserted tap the other side bush into place. I used some of this to lightly lubricate the bushing before the final install;
Tap both bushings into place now;
And then push the steel sleeve into place;
Now we need to check for how the steel washers fit over the assembled bush and sleeve. To do that we will use the washers numbered #1 - 4. Start with the #1 and a .012 feeler gauge.
I got lucky on the first side and everything fit great;
The other side had a bigger gap;
I used a #2 washer and the gap was spot on;
Now repeat on the other TA and you are ready for them to be reinstalled or to use Richard's kit that allows for easy adjustment.
