G
A little hint for keeping your carpet dry(-er). How many of you have those little nuisance leaks through your firewall from rubber grommets that dry out or stretch enough to let water in when you wash your engine bay. (You all DO wash your engine bays, right?) I have found that NAPA sells butyl rubber rope that is used to seal windshields and a small section of this rope will putsey nicely around and over an existing grommet, self seal to itself to make a continuous seal that will stick to the old grommet and firewall and wires for a beautiful seal that won't leak and can be redone and you can shape it with a little spit. (run-on sentence? I think I need an AlkaSeltser)
Bill
Bill
