When the time comes for final assembly of the interior, I have a bunch of the aluminized heat shield blanket that will be installed. The plastic tunnel cover is already installed, and I have some thicker padding for under the carpet, as well.
Mine is an overdrive car, and I've got a Salisbury type limited slip 4.10 rear end I may just drop in to see how it performs. Or, the 4.56 I also have would make it a real "screamer". Literally!
Jeff
Jeff
