Spitfire GT6 with Spitfire hood.
Reh
I always see Spit 6s but has anyone put a Mk1 Spit hood on a Mk1 GT6?
SpitBang
You could, but it would require a shorter engine as the hump in the hood is partly there to clear the valve cover. Alternatively, the engine can be moved back by about six inches and that'll give enough space for a Spitfire hood to be fitted.
Reh
Reh
racingenglishcars said:
If you're referring to the bonnet, with a smaller engine it should fit. I wasn't aware that Americans would actually install a <span style="font-style: italic">smaller</span> engine
Well my father is thinking about getting a TDI from a wrecked jetta, and the TDI is a bit shorter.
Andrew Mace
I know someone in the Massachusetts area who made a "tribute" Le Mans Spitfire using a GT6 body and a Spitfire engine. Of course, the Le Mans Spitfires (as were all the "Works" Spitfires) were four-cylinder cars.
And yes, the bonnet will fit fine over the four...or over the six if you a: move it well back or b: have the bulge. Alternatively, one can do what someone did long ago with a GT6 I bought from a junkyard. Presumably the original bonnet was damaged, so someone cut the bulge from it and grafted it onto a "Mk1" Spitfire bonnet. Looked fine if you ignored the 879 lb. of plastic filler used to blend the bulge into the top of the Spitfire bonnet! :hammer:
Richter12x2
It'd be interesting, but I'd expect quite a bit of work getting that FWD engine to mate up. If you do it, keep us informed on the work with lots of pictures! As cheap as those engines are and how easy the engine and tranny come out of the GT6's and Spits, it might be fun to have a 65mpg conversation piece!
If you're after not quite as much effort, there's a lot of aftermarket for the 1.8L Miata engines, and transmissions are super available (used in all the B series trucks, and some Rx7s, also.) Harder to find, but a BIT more technically accurate, there are some rear wheel drive nice Ford Engines (like the Ecotec, but with a different transmission bolt pattern, I guess?). It's the weapon of choice for the Caterham 7 clones, because there's a lot of neat work with these engines in Britain, but not much makes it's way across the pond.
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
D Spitfire GT6/Spitfire heater Ducts Triumph 3
W Spitfire Spitfire or GT6 wheels Triumph 1
W Spitfire Spitfire / GT6 bonnet Question Triumph 7
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
UmmYeahOk Spitfire Misc GT6/Spitfire Questions Triumph 9
Reh Spitfire GT6/ Spitfire to 4x100 Triumph 5
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
R Spitfire GT6/Spitfire Lighting Questions Triumph 10
UmmYeahOk Spitfire GT6/Spitfire E-Brake Button Triumph 7
B Spitfire spitfire transmission conversion to GT6? Triumph 5
Reh Spitfire GT6 and Spitfire look alikes Triumph 3
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
T Spitfire Spitfire GT6 cover Triumph 2
svtmikey Spitfire GT6 and Spitfire Dual brake M/C differences Triumph 9
WedgeWorks Wedge Ultimate TR6, GT6, Spitfire & TR8! Triumph 11
eschneider Spitfire spitfire GT6 rubber source??? Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
TheAssociate Spitfire Spitfire and GT6 diffs... Triumph 8
nathandarby67 Spitfire Spitfire / GT6 Dashboard Help Triumph 13
CinneaghTR Spitfire Spitfire/GT6 Owners! Get your Silverstone Wheels! Triumph 12
S Spitfire GT6 Roadster or Spitfire 6? Triumph 27
bcliff Spitfire GT6/Spitfire parts need a new home, FREE! Triumph 4
G Spitfire Lost & Found: Spitfire & GT6 Magazine *DELETED* Triumph 5
F Spitfire Differences between Spitfire and GT6 Chassis Triumph 2
TR4 Spitfire 1/43 Scale Model of TR4, GT6 and Spitfire Triumph 5
D Spitfire Best place to find a Spitfire/GT6? Triumph 9
Beavis Spitfire GT6 and Spitfire aerodynamic drag coefficient Triumph 11
KLUTZ Spitfire Spitfire / GT6 Magazine at Chapters Books ! Triumph 3
78Z Spitfire 70 GT6 parts better than 74 Spitfire parts? Triumph 4
M Spitfire GT6 or TR6 in a Spitfire? Triumph 14
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
C GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
