Richter12x2
I did retighten the screws after I loosened them, so they're not loose on top, still snug, just not torqued down as tight as I can comfortably get them, which has kinda been my habit. Also, I took care to tighten them crosswise, which I didn't do last time - maybe tightening too much and tightening one side all at once was holding it cocked? Now I can adjust the throttle by hand and watch both carbs open evenly and close when I let it off.
These were brand new filters from Victoria British, literally seen maybe 5 miles, but even then they ran badly. As I'm remembering, the time that I drove to the end of the street and back and everything felt awesome, I had forgotten to put the air cleaner back on. Like I had said before though, this doesn't seem like a normal paper element filter, these are hard and thick and yellow, and feel like construction paper over any paper element I've used in any other car.
And also, I never was able to adjust the mixture enough to make it run well with the filters - I'm talking drastic difference, as in, the car will idle well, and rev well, but if I put on the air cleaner with the engine running, the engine dies. Was Tegler the one that did research on the mix screw for those carbs that said that you really can't adjust the screws it to the point that it won't run?
