Beavis
GT6+ electric vehicle project. Need Info/Advice.
I'm looking at partially restoring a 1969 Triumph GT6+, and making an electric car out of it. There are some things I would like to know about it to get an idea of what to expect.
I have not been able to find any solid numbers on the drag coefficient of this car. I found a simulation ran online that had the Cd of the Mk1 GT6 at .47, I found .42 for a 1980 Triumph Spitfire(Being a convertable, it seems like it would fare worse than a GT6), and I talked to someone who was selling a GT6 that put the number at .32.
I know the cross-sectional area, 14.9 feet square, but the Cd number holds importance in simulating the car's range per charge, top speed, and 1/4 mile performance.
Also, the car has a TR6 drive axel and TR6 non-overdrive transmission installed. I'm looking at 200 lb-ft of torque from the electric motor, from 0 RPM up until about 4,000 RPM. Could the TR6 tranny/diff handle this amount of power?
How much weight could be lost by removing the GT6 engine and its ancillary components(like all hoses, fuel lines, carbeurators, exhaust, ect.)?
How much weight could be lost by removing an empty gas tank?
How much weight could be lost by removing the spare tire?
How much weight does the car's battery to power its electronics and lights have?
How much does the stereo system and speakers weigh?
How much difference do the TR6 and GT6 transmissions and differentials have from each other, and which weighs more?
Any low-rolling resistance tires that have decent road holding anyone could recommend that fit the car’s 13-inch rims? I know these two variables are mutually exclusive, but I'd like to cut down on losses as much as possible, while maintaining the car's high-performance handling characteristics. There are tires for other rim sizes that have managed good road holding and traction with coefficients of rolling resistance of less than 0.9% of the weight of the vehicle. I’ll also need some traction to make use of that low-end torque.
Thanks for answering.
If you have to ask, I'm looking at building an electric sports car that will go from 0-60 MPH in about 6 seconds(perhaps faster), top at least 110 MPH(Given the TR6 tranny/diff setup and max motor RPM for the series DC motor set at 6,500 RPMwith 13-inch rims, I'm looking at about 120 MPH top speed, about 130 with motor limit at 7,000 RPM), and have a highway range per charge of about 40-50 miles to 80% depth of discharge of the battery pack. Charge time will be about 2 hours from a 220V outlet from 20% state of charge to 100% SoC.
As bad as I feel about doing it, this poor car is going to be butchered all because I want to build a fast and sexy-looking EV to cruise around in(And humiliate unsuspecting ricers at a stoplight with.), and what better choice than one of my favorite types of car, a Triumph GT6? Not only am I going to have to weld in battery boxes and custom fabricate motor mounts to place into the car, but I'm also going to strip out the interior and build into it a custom interior almost bare of any trim, change the seats to a lighter variety to shave off about 45 pounds, and on the exterior remove the chrome strips from the car, shave down the door handles, install leaf springs to increase the GVWR of the vehicle(As a conversion it will weigh about 2,500-2,600 pounds including driver, while stock GVWR is about 2,350 pounds), cover the grille from the inside with some sheet metal, make the toe 0 degrees, machine down the flywheel to reduce inertia losses(Doesn't need to keep the motor revving at a stop, it's electric and has plenty of low-end torque to not need this. Will be like removing 150-200 pounds from the car while accelerating hard), cover all unneeded exterior vents, lower the car closer to the ground by about an inch, build and install a full underbelly, partially cover the rear wheel wells with fiberglass, close any seams, remove passenger-side mirror, and machine the brake disks to be more circular in shape to reduce brake drag. This is all going to be done to maximize efficiency by reducing weight and aerodynamic drag as much as possible, shaving aero drag down by about 20%. A roll bar will be installed to meet SCCA guidelines so I can use it in racing.
Later on after the car is completed and usable, eventual add-ons will be to install an aluminum LeMans style bonnet, fiberglass doors, fiberglass hatch, lighter windows, remove front bumper and install two rounded bumperettes to fit custom bonnet, all to reduce weight even more, perhaps getting the car's curb weight including driver down to about 2,350-2,400 pounds and the LeMans style bonnet would slightly decrease aero drag.
I want to make this look like one of the classic LeMans Spitfires to an extent.
It will have the look of the ADU 4B LeMans Spitfire pictured here(Only with about the top third of the rear wheel well covered, smoother body, no exhaust pipes, won't have the fog lights the LeMans Spitfire has, ect.):
But it won't have that sort of paint job. It's going to be one color through the entire car, the sort of dark green/black paint job Picton Sportscars Ultimate-Spec Spitfire has:
For the interior, it is sort of going to look like that of the electric VW Karmen Ghia pictured here, only instead of red, the GT6 I have planned will have a dark green/black interior color and theme:
After stripping the car's basic sound system out, I'm going to install a 500 or 600 watt high end system from a manufacturer like Bose or some such, but only if it won't weigh more than the car's stock radio system. I want it to be as light as possible, only having creature comforts and such if they don't up the weight too much. An air conditioning system is not initially planned, but may be added later.
Battery boxes will be placed in such a way so to have about a 48-50% weight distribution front, 50-52% weight distribution rear, and placed as close to the center of the car as possible to reduce polar moment of inertia, while keeping as much trunk space as possible. If at all possible, I want to sink the batteries into the floor. The lower the center of gravity, the better. It will no doubt be lower than stock, as long as all the heavy components are placed below the top of where the engine block used to be, as a rule of thumb. Spare tire will be replaced with a can of fix-a-flat. This car won't be going on many long trips with lead acid batteries installed, and as an EV, it won't need tools to repair/maintain a fussy gas engine either since electric motors last over 500,000 miles, entirely maintenance free.
This car will be raced and taken to car shows for display, and be used for my daily commute back and forth to college and work. I want to keep it looking like a vintage racer from the 60s, but give it technology that is not put into the cars sold today (Political reasons, corporate greed, ect. I’ll spare the rant.).
The overall cost I'm looking at to partially restore it and convert it to an EV is as follows, broken down part by part how much this is going to cost me and how much weight each EV part will add to the weight of the stripped GT6:
-1x 1969 Triumph GT6+ in good shape = $1,200
-1x WarP 9’’ series DC motor, $1,395, 160 lbs
-20x Optima D750 Yellow top sealed deep cycle lead acid batteries, $2,760, 900 lbs
-1x Godzilla Controller(72-300V DC, 1,000 amp max), $2,495,
23 lbs
-1x PFC 20 Charger, $1500, 15.5 lbs
-4x Vicor DC-DC converter, $400, 8 lbs
-Steel for battery racks, $100, 50 lbs
-Battery Cable, $100, 20 lbs
-x2 EV200AAANA contactors, $150, 5 lbs
-x2 Feraz Shawmut A50QS600-4 fuse, $80, 1 lb
-x1 Curtis Potbox, $75, < one ounce each
-x1 E-Meter, $235, 1 lb
-x1 Solid-State Ceramic Heater Core(For heating in the winter), $75, 1 lb
-x1 Adaptor Plate, $1000(I will be machining myself, so
don't count cost), 40 lbs
-x1 Set of custom Motor Mounts, $1,000(I will be machining myself so don’t count cost), 20 lbs
-Miscallaneous components(Heat shrink tubing, renting engine crane, restoration tools, ect.), $800,
100 lbs(For stuff actually added to car’s weight)
-Leaf springs, $300
-Battery heaters, $200
-Paint, $1,000
I’m looking at a $13,000 or so initial cost, can go as low as $9,000 if I get motor/controller and other expensive parts used for cheap, and as high as $15,000 if I need a racing clutch and different tranny/differential. Minus stripping the car out, adding about 1,440 pounds to the weight of the car not counting the weight subtracted from stripping out the gas engine and other things. Depending on how much the GT6 engine and other gas-related junk I won’t need weighs, the final car will weigh somewhere around 2,600 pounds including driver. If weight is too much over that after stuff is stripped out of the car, the battery pack will be shrunk down, going no less than x16 Optima D750 for 192 volts in series. The batteries will be arranged in series, with a 240V pack planned out of 20 batteries in series, less than that if not that many can fit, more than that if more can fit and weight including driver is still < 2,600 pounds. The DC motor is rated to 192V and can be taken up to 6,500 RPM with absolutely no damage(I’ve heard as high as 8,000 RPM), at 1,000 motor amps(controller limitation) neglecting back electromagnetic force, produces 380 lb-ft of torque, and counting in bemf losses produces about 200 lb-ft of torque. The 200 lb-ft is what will reach the tranny for hard acceleration. Horsepower counting in bemf will be about 180 at the flywheel, 120 or so at the wheels.
Since I'm a college student majoring in electrical engineering, I'll eventually be building a Lithium Ion battery pack for this car once I gain the know-how, which would store enough energy to give it a range per charge in excess of 150 miles at 70-80 MPH speeds(200+ miles per charge cycle drive or at 50-60 MPH speeds) to 100% discharge and light enough to push the car's weight including driver down to less than 2,000 pounds with planned lightweight bonnet, doors, ect, 2,200 pounds without those upgrades.
I checked the GT6 I'm looking to convert, rocker panels had some rust but was so thin a magnet stuck anywhere on the panels so rust could probably be sanded off, no rust on the bulkhead or under battery area, chassis outriggers were in great condition, gearbox has no worn synchros and works great, master cylinder and brakes function perfectly fine, electrical system is perfect(although will be gutted and upgraded anyway).
Having never done any major work on a car before(Nothing aside from installing a performance chip in my gas-guzzling Ford Contour, changing the battery, and changing the oil), this will be a daunting task. I have planned out the steps I’m going to take for this.
1) Strip the interior
a) Replace the stock seats with lighter seats(-40 pounds
after replacement seats are put back in)
b) Remove all carpets(-15 lbs)
c) Remove all sound deadener(-25 pounds)
d) Remove wood panel dash, replace with custom leather
dash(-5 pounds)
e) Shave down or perhaps even remove bumpers(-15 to -40
pounds)
2) Measurements
a) Drive car up to get weighed
b) Calculate where to position motor/batteries for about a
50/50 weight distribution, battery box needs, ect.
3) Fix alignment and get car to have 0 toe. Remove gas
engine, gas tank, air conditioning, ect. You know the rest
on that part. Weigh each component removed and record its
position. Tow car over to get weighed again and get glider
weight and weight distribution.
4) Restoration
a) Take the newly placed in interior parts and carefully
remove them
b) Clean all grease! There's grease under wheel wells,
around the tranny, around the engine, ect.
c) Strip off the tacky yellow paintjob that was
done to make the car presentable to a prospective
buyer
d) Sand down any and all rust from all parts of the unibody
e) Rustproof everything
g) Re-paint the car. I'm looking at what appears to be a two-tone color that
alternates between Dark British Racing Green and Black
depending on how the light hits it. I want to make the car
scream "I'm an attention whore and I attract crowds of
people that ask dumb questions like what kind of car am I
and how fast do I go while my owner always has to tell them
it's not a Ferrari or Jaguar and then spouts off some track
time that no one understands! Don't even get me started when
he sits there with my hood popped open at the local gas
station, or the time he took me to get ‘emissions-checked’ during the registration process..."
h) Put back in the aftermarket/custom interior pieces I took
out
5) Conversion
a) See if a new racing clutch to handle torque. If it is? Buy and install one.
b) Basic aero mods done to EVs like underbelly, covered
grille, ect.
c) By now, a motor will be bought.
d) Fabricate adaptor plate for tranny
e) Fabricate motor mount. May involve moving cross members to
make room and will not be done if can be avoided.
f) Fabricate battery boxes. Want batteries as low as
possible and want a very low CoG for handling
g) Buy needed EV components that aren't purchased by now
h) Install said components
6) Drive EV, hunt down all sources of unwanted drag, correct
discovered problems
7) Post Conversion(In no particular order and some perhaps
years after EV is on the road)
a) Professional driving course so I don’t kill myself in this thing doing something stupid
b) Experiment with different types of LRR tires
c) Machine down flywheel
d) RACING
e) Aluminum LeMans bonnet, fiberglass doors, fiberglass
hatch, aluminum alloy wheels, lightweight
windows(-200 to -250 pounds)
f) Lightweight but decent power stereo system
g) Transmission upgrade to a Datsun 240Z tranny/diff if the TR6 unit cannot handle the torque well enough
h) Zilla 2k(Higher power controller means more power to the motor. More amps = more torque. With 500+ lb-ft on tap in such an upgrade, I’ll NEED a beefed up tranny/diff for this upgrade)
i) Use my college education in EE to design a management
system for Li Ions and build a Li Ion pack!(Waaaay down the
road)
Does this sound at all the right way to go about things? Any advice? What tools should I look into? I’m certainly no car expert.
If anyone has any questions about electric vehicle technology, I’ll gladly answer them, although the posts might get a bit long.
Thanks.
23 lbs
-Leaf springs, $300
-Paint, $1,000
dash(-5 pounds)
pounds)
2) Measurements
4) Restoration
remove them
buyer
out
5) Conversion
grille, ect.
discovered problems
d) RACING
road)
Thanks.
