19_again
The po has some webers and offered them to me when I bought the car, I'm now considering making him an offer for them. I recently wrote and asked if he still had them and this was his answer "<span style="color: #FF0000">Yes I still have the Weber carbs. They are 40 DCOE side draft. There are 2 with a "40 DCOE 2" stamp and one with a "40 DCOE 151" stamp. All three carbs are mounted on an intake manifold with a single rail type linkage. I have a few odd jets/emulsifier tubes as well.
The vendor for the setup told me that the intake manifold was for the GT6. I now understand that the manifold is likely designed for the TR6/TR250 since it has straight runners. The manifold mounting flange for the TR6/TR250 and GT6 are identical. However, there is less hood clearance for the front carb under the GT6 hood. The correct intake manifold for the GT6 should have an offset downward to allow for hood clearance."</span>
I am asking for your advice regarding whether to continue the quest and what these carbs are actually worth.
Thanks, Mike
Thanks, Mike
