GT Update
Been a while since I've posted, but progress has been made.
I've been tidying up some of the wiring and plumbing, and have sorted out some running issues. I've driven the car a bit, but still a bit timid about venturing out any great distance. It's now time to change the break-in oil, and once that's done, hopefully will have the opportunity to take it for a bit longer drive.
In the meantime, Friday I managed to install the evaporator/blower assembly for the heat and A/C. Thanks to some ideas gleaned from other folks, I decided to pitch the little control pod for the fan switch and temp control - this little lovely:
...which can be mounted alongside the center console or ~wherever~, and which looks kinda tacky.
So, here's where I put the controls:
Looking right to left, there's the hazard switch, the temp control, a port for 12V power, the fan switch, and a dummy switch which can be used for something else down the road.
And here's the evaporator/heat exchanger/fan unit under the glove box. Still plenty of leg room:
Gettin' there!
Gettin' there!
