Nunyas
just a minor little vent here. Nothing much other than me getting minorly upset with myself, and old parts.
As I've mentioned somewhere else on the board, I found that my car is missing the heat shield ('76 B). I just got it Monday, and finally had time and daylight to install it today. While installing it, I found that I had to reposition the radiator to heater pipe (it runs under the heat shield on '76s) I tugged on the hose a bit to get the pipe to line up with the hole in the heat shield and mounting plate. I got it into position, but the 30 y.o. pipe was so corroded and weak that it cracked and spewed out all of the coolant that was in the heater core. /ubbthreads/images/graemlins/pukeface.gif
It's kind of funny after the fact, but at the time it irked me, because now the 'B is out of commission until a new pipe arrives from Moss. *sigh* Ah well, I knew engine was running too good for too long, and it was about time for something to happen to put her out of commission for a couple of days.
