Grommet in rear battery cable panel
AUSMHLY
64 BJ8. Is Moss' part number 680-288 grommet kit used in the rear battery cable panel?
If that is correct, does the outer metal grommet ring get screwed through the Armacord, or does the Armacord get glued on top of it, so you don't see it.
Thank you, Roger
Hi Roger,
Looks like the metal grommet bracket goes under the Armacord. In this photo, you can see a slit cut in the material. In the Anderson/ Moment guide, page 179, the Armacord has a round hole cut so only the rubber grommet is showing, not the metal.
