Ok here is the deal. The only seals in the axles iare an o ring and a paper gasket.
The paper gasket you cah make from a paper bag and put a bit of form a gasket on it when you install it.
The O rings are cheep, like 50 cents at your local auto parts store. They keep them behind the counter, all sizes. Take an old one for fit.
It is my opinion that your shoes only need cleaning as long as there is remaining material. The old time material on shoes, like 40 years ago, absorbed oil. That was when aspestous (sp) was used. The newer lineing do not absorb oil. Scrub em real good, your choice of solvent but something that removes oil, heck 409 even and a tooth brush.
Brake hose is going to have to come from Tony. Is it leaking? Why does it need replaced right now?
Reassemble, adjust brakes and go for a plesant drive.
Hay Zimmy, I was 16 and had a 40 ford hot rod. Ran like stink. Funds were very short. I made do.
