BlueRidge2
There are 6 tabs fastened to the surround. What does the middle tab on the bottem fasten to???
Is there a process or sequence on installing the grill?
Seems as if it would be difficult to install on a freshly painted car with out scratching the shroud. Would I be
better off to install the grill prior to painting then masking it or install after? The grill has the vertical bars. Thanks Bob
Hi Guest!
