G
Rewiring the rear of my car and committed the ultimate sin...didn't leave the original Lucar connectors connected to light bulbs. OK, which goes where? Green/Purple and Red wires to the combination Brake/Tail light bulb. The darn bulb socket has two spade connectors on it, one Silver and one Brass. Which wire goes where? The darn Lucar connectors are the same size, as are the spade connectors on the socket.
I hate when I do dumb things.
Oh, and why am I rewiring the rear of the car? Well, right turn signal doesn't work and I tried everything to fix it. So, I got a new Lucas turn signal and a new rear harness (the front harness is new British Wiring). This will finally make the car officially New. Everything else has been changed. Oh, and the problem? One of the wires inside the turn signal switch had abraded over the years and grounded out every time I tried to turn right. Short circuit...pulled a Johnny 5.
