TR6 Greasing the TR6 urgent help needed
hondo402000
I decided to grease all the joints today and got most done but I cant seem to figure out how to grease the rear half shafts the slip joints in particular, there are no grease nipples need some help as I am doing it now,
I don't think there is any simple way to grease the slip joints with the shaft on the car - you would have to remove the rubber boots which I wouldn't want to try with the shaft on the car.
well I pulled the boots back and put some grease on it , probably not the best way to grease then but not pulling them of the car at this point I will wait till I pull the diff to have it rebuilt and then grease them, I might ever drill and add grease nipples too
