Jay,
Do you care to share the source of the part.
Charley
Had one come out while I was driving. Scared me half to death. Thought the wheel was coming lose.
David
If you can find a piece of pipe or socket that is close to the size of the ID of the cap, slip the cap over it and make a few center punch marks around the OD. This might raise the metal around the marks enough to make the cap a tight fit in the hub.
Berry
bought two from TRF. Both the same. Just ordered two from Moss; will check them out.
in dealing with AM parts it can be hit or miss. Don’t blame TRF just a miss
Indeed. And TRF's response to me has always been to replace the defective product as soon as they can.We all understand that the suppliers like TRF and Moss keep getting new stocks of parts. And anyone of those new stocks can contain a bunch of faulty parts. So it is best to notify the supplier of the problem so they can work to get it corrected. It is how they deal with you from that point that makes the difference in a supplier that you want to continue to order from.
That's right; the hubs only had different part numbers because they came with the studs loaded in them. Only the studs are actually different.FYI, I am changing from wire to disc wheels. Have not found where the hub needs to be changed as well; just the studs.
