Grandpa's Bugeye
  • Thread starter Deleted member 9684
  • Start date
Deleted member 9684
So...grandpa's 1961 bugeye has been sitting since 1987 when my dad moved it from one garage to another(about 1/4 mile). It ran and shifted and stopped well...Before that, it had last been run in 1969.
My grandfather bought the car in 1963 from the original owner.
Not sure of the specifics on the engine other than it has a Judson supercharger on it (the orig carbs are in a box in the garage).
I'm wondering what I will need to do to get this thing running again. I intend to drain and replace all of the fluids, but I'm not sure what to replace them with:
Engine - which weight/viscosity should I use?
Transmission - not sure...ATF?
Rear-end - really not sure...
Fuel - Can I run unleaded?
Coolant - 50/50 mix i assume...
Also, can I just hook up a 12 volt battery to this car or is a different voltage system?
The car is in ok shape...just a small amount of rust in the usual spots, interior is all there, but needs replacing...
My last question is does anyone know a reputable british car mechanic on Long Island, NY?
Any help would be greatly appreciated!
Sean
aeronca65t
Welcome!
<span style="color: #FF6666"> 10W-30 in Winter and 20W-50 in Summer will work fine</span>
<span style="color: #FF6666"> 10W-30 engine oil for a Bugeye trans.....yes, normal *engine* oil</span>
<span style="color: #CC0000"> Normal gear oil Gear 90W-140 is fine</span>
<span style="color: #FF6666">unleaded high test is fine </span>
<span style="color: #FF0000"> yes</span>
<span style="color: #FF0000"> normal 12V battery. If is hasn't been modified, the ground will be positive (+). Some cars have been changed to negative (-) ground. If it still has the standard generator with tach drive cable, it's probably positive ground</span>
<span style="color: #990000"> Not sure about mechanics in LI. But I know someone out there who might....give me a few days and I'll see</span>
tony barnhill
Great Pumpkin - R.I.P
RickB
<span style="font-weight: bold">There are some Long Island Spridget owners on the spridget listserve:</span>
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]To subscribe or unsubscribe via the World Wide Web, visit
https://autox.team.net/mailman/listinfo/spridgets
or, via email, send a message with subject or body 'help' to
spridgets-request@autox.team.net
[/QUOTE]
I know at least one of them has a Bugeye.
One of them could probably give you a reference for a good mechanic.</span>
Bugzy59
The bugeye shares a number of components with sprites and midgets through 1973 so a lot of the technical advice for later cars will be applicable.
Have fun - great that your family has a history with the car.
Deleted member 9684
Thanks for all the info. I found the MGB article in particular a very comprehensive piece. I plan to print it out and tape it to the windshield.
Any leads on semi-local mechanics to help me in a bind would be great.
Thanks again. Looks like a great forum!
I'm heading to the garage tomorrow to take some photos to post.
I've seen MUCH worse. I'd say that is an excellent candidate for a proper restoration.
John Moore
It look absolutely horrible! I think the best thing to do is give it to me so I can "dispose" of it properly! lolol :laugh:
You might try contacting these guys for recommendations for a mechanic.
https://www.mgcars.org.uk/mgcclic/
Also.... is it a Sandy Beige Color? Or more of an Off White (old english white) it's hard to tell on my monitor.
Deleted member 9684
Thanks John...will contact the MG club.
I think the car is the old english white...but in such bad shape that it looks beige.
what are the proper colors? was there a beige color?
jvandyke
I find myself wishing I had a Grandpa who left such things .....but I can be that Grandpa someday.
John Moore
Whitephrog said:
Whitehall/Nevada Beige? If so, a rather rare color.
Yep, that's what I was wondering. I've never seen one that color in person.
tony barnhill
Oh, man...I'd disassemble that little sucker - every nut & bolt - & put it back exactly as it was whe it rolled out of the factory!
Pythias
Yeah, Tony, but you're a junkie who always needs a fix.
jlaird
Me too and I would be pleased to take on that job.
I know next to nothing about BE but I'm fairly certain as well that that is not Old English White. And that supercharger has been there a very long time! Would that have been a dealer install? Owner add on VERY early in it's life? That would be a FUN restoration, being Granddad's car and all!! :laugh:
True, not only is the supercharger a period piece, but it was installed on that particular car during the period. Do you have any old photos of your grandfather with the car?
RickB NMC - Grandpa x2 Spridgets 10
Brooklands Vehicles from Grandpa's photo album Other Cars 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
jfarris Immaculate 1958 Bugeye Spotted 4
drooartz Leno's Bugeye Spridgets 12
R BUGEYE SOFT TOP FIT Spridgets 2
R Bugeye splined wheels Spridgets 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Basil For you Bugeye/ Frogeye fans Spridgets 5
B Bugeye Electrical Diagram with additions Spridgets 6
