Our '60 Bugeye is now amongst the living - and driving!!!
As part of the fixing up of the mistakes made in the previous restoration, we installed a T9 5-speed in our bug. Combine that with a Triumph 2/3/4 rear end and, surprise, the speedometer is anything but accurate. OK, I need to pull it and see if I can "adjust" it to read closer to reality, but for now it seems to be off a consistent 10 mph from 20 to 70 mph. And yes, our bug is very happy at 70 mph - seems to just get in a groove and is much more stable than I expected.
OK the long intro is my attempt to make the 500 words minimum. But you probably needed to know all this anyway.
So, speedo off. Lots of alternatives. Send it off to a specialist and have it redone to get the correct gearing for the tranny and diff. Or, well, there is the rather pricey option of installing a GPS unit that spins a speedo cable – which means locating a new unit under the bonnet and then routing a cable. And adjusting it so it will work.
Or, something I never thought of, you can go to Amazon, spend like $50, and have a rather nifty digital speedo that you can install where ever you want. Provided you can run a wire to it.
Here is a shot of the GPS installed in our bug:
Even better, it comes with a compass. For those moments when we are truly lost and have to rely on dead reckoning.
I was able to mount it using one of the screws used to mount the trim above the dashboard - granted, I had to machine a screw to fit the slot in the back of the digital speedo, but, with a clock shop full of micro machinery, that was easy.
Here is a link to the GPS speedo I bought:
https://www.amazon.com/gp/product/B0BG6VVXCW/ref=ppx_yo_dt_b_asin_image_o00_s00?ie=UTF8&psc=1
And a link to a USB power supply to drive the speedo:
https://www.amazon.com/gp/product/B08DFQKSQG/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
For under $50 you can know how fast you are going! So far the speedo has come up about as soon as I start moving – though yesterday, deep in the woods, it took it 4 or 5 miles to “find” itself.
And, hey, you can change colors on the speedo!
Darned, only 413 words – maybe the word count gods will let me get away with this – perhaps the pictures count for 50 words each?
Stephen
Stephen
