Seems the carbs were set WAY too rich. When I finally got them dialed in, as best I could, the jet is actually about a quarte turn from its top, as view when the damper and piston are removed.
Also, the slow idle screws are all but a half turn from bottomed out.
Turns out this all means the throttle shafts are worn and leaking lots of air. This proved true. The test is to squirt some carb cleaner on the shafts at their point of exit from the carb body. If the engine RPM changes, air is otherwise getting in. The far front seal had LOTS of air getting in.
Seems I can dial in the carbs to compensate, and things apparently run OK. But the choice is either to a) do nothing else. b) get the premium rebuild kit and also service the shafts/bushings, c) send them to Joe Curtto or some other qualified rebuilder, or d) shell out the bucks for a new set of HD's.
Has anyone been down this road and can give advice?
