Thanks Jody,
Am still procrastinating about getting to doing something, so it's not too late to change my mind. The pump gasket is the one that was sent with the pump from JHPS. I also have the stainless steel mounting bolts and washers. If you have the torque specs on those bolts handy could you get back to me with them? I've got the book, I'm just lazy. Guess I'll have to go to the shop, where I work and get my torque wrench, too. I'd better check the valve clearances while I'm at it as I've put that off too long already. If I'm going to all the trouble to put the kits in the carburetors it would sure make sense to do the valves. I'm pretty sure I have the good valve cover gaskets, but will clean the threads carefully when I go back with them. I least putting the new distributor on will be easier with the carbs off. I'm going to town now to do a little shopping then will get after it.
