Gearhead_Garage
This forum has been very helpful to me while I sorted out the brakes on my BJ8 Phase I without a booster (basically BJ7 brakes). I thought I would share my experience for others.
Being an early BJ8, the car probably came with a brake booster but it did not have one when I bought the car. Even 20 years ago, the booster was NLA and I decided I could do without it since most Healeys were shipped that way.
The car was built with all new components including a BJ7 5/8" master cylinder. Despite all manner of bleeding, I always experienced excessive brake travel and inadequate deceleration. Perhaps I had a bad master cylinder.
Based on a forum search, to get a firm pedal, I swapped the master cylinder for the Lucas 7/8" unit from Moss, part number 581-100. It appears to be a higher quality component than the cheaper 5/8" and 7/8" units available from Moss but the line locations need some tweaking for connection. The larger diameter bore moves more fluid for the same pedal movement so the pads get snugged up with less movement. This should result in a firmer pedal at the expense of more effort required due to less hydraulic advantage.
After bench bleeding and installation, I finally got a rock hard pedal with very little travel. My enthusiasm was curbed when I drove it and it took Incredible Hulk levels of pressure to stop the car!
Back to the forum for some advice on more aggressive pads. I ordered up a set of Porterfield R4-S pads, installed and bedded them in. Wow, what a difference.
Finally, a stiff pedal that allows good modulation and I can lock up the brakes if I press hard enough. Hopefully the dust won't be too bad.
