Gold Sparkle in Oil
Changed engine oil yesterday and saw gold-colored sparkle when oil sat in sun. Any idea where it might have come from?
gonzo
Re: gold sparkle in oil
Would that be an engine component made from brass or copper? Any of this captured by the oil filter or all in sump?
There's a couple bronze thrust washers on the crank. Check endplay on the crank by watching the balancer and pulley as someone pushes on the clutch. I think the top pushrod bearings might be bronze, and the rocker arm bushes are.
Bob, is that with the engine running? Pushrod bearings? Wouldn't that wear fast if they were bronze?
Doesn't have to be. There is some end play--offhand, I'd guess maybe 1/16", but I don't know the spec--but if it seems excessive, like a half-inch it could be you've lost one (there's two, each in two halves). It's been a while since I had my BJ8 engine rebuilt, but I do believe the upper pushrod bearings are bronze, and I know for sure the rocker arm bearings are. My BJ8 engine has bronze valve guides. As usual, if I'm wrong someone please correct me. These aren't Healey, but you can see they have a soft metal upper bearing:
https://www.ebay.com/itm/New-Racing...360869&hash=item42280f802e:g:bjQAAOSwpqVfWzyX
Oil analysis isn't a bad idea, but I'd probably drop the pan and see if there's any chunks in there. Bronze is used in some metal-to-metal applications where it's better if one side is a bit softer to prevent wear on both parts. There are bronze thrust washers in the O/D too. Note when I say 'bronze' it could be other yellow metals; e.g. the gearboxes have brass shift forks, and I usually some extremely fine yellow 'shake' in gearbox oil when I change it (it's actually kind of pretty).
How was the oil pressure itself hot?? If you have low pressure, could be the main and/or rod bearings have worn to the underlying copper. Ans noted, maybe thrust washers that would be on either side of the center main bearing cap. Wear too much they could fall out and cause damage to the main caps and crank thrust surfaces which if bad enough could require replacement. And as noted there are other bonze a copper in the engine. In the end you'll probably be dropping the pan.
dancrim
If you haven't replaced the oil yet, pour 1/2 gal. of kerosene in it to flush the pan.
Let the oil and Ker. sit overnight and use a magnet to check if it is steel or
bronze. If bronze, more than likely you have spun a rod bearing.
tahoe healey
I was thinking bearings too. The oil pressure is very good and no noises. Runs well. I was just getting her ready for Big Bear in May doing per-season stuff as it will be a significant number of miles. I will stic a magnet in the use oil to see if anything sticks.
John Turney
... upper pushrod bearings ....
Connecting rod. That's what confused us. The pushrods are the ones between the tappets (or lifters) and the rocker arms.
Rocker arm bearing wear is usually the first to cause low oil pressure. Since TH's oil pressure is good, I wouldn't expect wear there, although removing the oil filler cap with the engine running will allow visual inspection for excessive oil flow.
Rod bearing wear will show up as noise.
Main bearing wear will also cause low oil pressure.
Thrust bearings could be an issue. End play in the crank should be between 0.0025" and 0.0055".
Also if the rubber foot on the timing chain tensioner or vibration dampener is worn.
dancrim
A Con. rod would be hard to hear in an engine that heavy. (meaning thick iron). You rev it up to mid rpm
then let off the throttle, At that instant you will hear it. Went through this with a Ford big block.
Healey Nut
Oil analysis , stethoscopes, vibration analyzing, boroscopes etc ......Nothing beats pulling off the oil pan and getting a real set of eyes on it .
Pulling the pan on a Healey is quick n easy .
Cutting the oil filter open--with a suitable tool (NOT a hacksaw)--would be in order IMO. I usually do an oil change before a long road trip, and I cut the used filter open to inspect for unwanted chunks of stuff. We did this routinely on the aircraft I helped maintain.
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
HealeyRick Gold Level Concours Value Austin Healey 20
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
B Gold TR8 Waxhaw N.C. Spotted 2
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
S TR6 Gold stars for TR3Driver&NutmegCT: it's a fuel delivery issue Triumph 9
steveg Moss Classic Gold 7 lbs. cap now "sucks"! Austin Healey 0
P Guages with gold rings Spridgets 2
B TR6 How restore the "gold" finish of TR6 door latch? Triumph 4
K Gold in the junk yard Triumph 5
Michael Oritt VIR Gold Cups/ACME SPEED SHOP Racing 1
PeterK TR2/3/3A Classic Gold TR3 Master Cylinder Triumph 2
HAN8L1965 Found Gold Spridgets 14
angelfj1 Warning - Moss Classic Gold Master Cylinders MG 0
angelfj1 Warning - Moss Classic Gold Master Cylinders TVR 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Spridgets 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Austin Healey 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Lotus 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Jaguar 0
AngliaGT "Classic Gold" Water Pumps MG 2
T Free Dunlop Gold Seal 5.20 13 bias ply tyre Spridgets 5
M VIR GOLD CUP THIS WEEKEND TVR 0
S Gold Wheels MG 8
Sherlock Emoticons & the new Black/Gold style FORUM Navigation Questions 2
jerrybny Classic Gold Semi-Metallic Brake Pad Set Triumph 2
Jim_Newman gold cylinder head Jaguar 4
Newkie Napa Gold oil filter MG 5
healyfan53 Barret J. vs Gold concours BT7 1960 on the block Austin Healey 23
JeffR Thanks for all the help - Gold! Austin Healey 4
S VIR Gold Cup Historic Auto Race Photos Racing 1
G T-Series What is a MG TD "Gold Seal" Engine? MG 17
Bret Gold Corvette Other Cars 20
Webb Sledge Gold Cup Race Pictures... Again MG 3
Webb Sledge Gold Cup Race Pictures... Again Triumph 0
dklawson Pictures - VIR Gold Cup MG 3
dklawson Pictures - VIR Gold Cup Austin Healey 10
dklawson Reminder - Gold Cup Races at VIR Start 6/10/05 Austin Healey 2
Webb Sledge Gold Cup Historic Races Triumph 1
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
