for anyone interested,i did pull the carpet,used nice heavy duty aircraft connectors at the batt,and installed a 15 amp aircraft type braker on the bulkhead just in front of the batt,contained in a small insulated metal box to prevent a jack handle or a cymbal stand (keoke)from shorting it out,then past the wire through the bulkhead just next to were the batt cable goes over the rear end using an appropriate size rubber gromet,secured with rubber clamps,drilled a hole in the area just above the rear floor in the corner were the bottom of the right rear side panel fits against the wheel well so the wires are hidden behind the panel,then under the carpet passing between the pass,seat and the door /ubbthreads/images/graemlins/hammer.gif,up the kick panel r/s,and up under the dash,to the radio,all secured with plastic clamps and tie wraps,very tiddy and well consealed,what do you guys think about the 15 amp breaker?think i could have used a 5 amp or 10 amp?we all know the radio doesnt pull much,and i just dont need a dc welder in the cockpit,i need the room for the drum kit(keoke)thanks all!!!!!!!
