GM Paint Codes
R6MGS
Where would I find the paint code on my 00 Sonoma? I don't have an owners manual to tell me, and I checked all the usual spots but didn't find anything. This isn't the first GM vehicle where I've had trouble finding the paint code, where are they hiding the dang things?
Ron, it should be on the menu in the glove box. Adhesive label stuck to the glove box door.
Did you know that with the VIN, a dealer can pull up the original build sheet, with all the installed equipment listed by RPO numbers, including paint, interior, and trim codes.
Jeff
ok,thanks...I've seen that label...it lists a bunch of rpo codes...is the color code seperate from those or is it in the chart looking thing with the rpo's?
Great, thanks!..Didn't even need to go over to the truck forum for this one!
