regularman
I started working a bit on the car and ended up getting quite a bit more done. The front end is now done and the rear is very close. I only have to wait on the fiberglass to set up that I put as a patch around the trunk. I had two little rusted out spots at the bottom where the panels were brazed together and I had to cut them out and glass them. For some reason the resin is taking forever to set, maybe its too old or something. I ground down all the welds on the new metal where the top mounts and put a bead of bondo around it to be sanded smooth tomorrow. I'm sure there might be a small place or two that will show up after some priming that will need some spot putty but otherwise I am almost there.
