DNK said:
Please remind me and all the others where the correct jack stand locations are so that the doors will open and close while it is "UP"
I am about to raise mine for a while and have forgotten the info.
While I'm sure it varies some from make to make, my experience has been if you want to limit chassis flex as much as possible, then support the car in such a way so that it mimics how the suspension does. This also depends somewhat on the work I'm planning to do.
For our Volvo's (Jerseygirl's and mine), I usually support the car by the rear axle under the spring pads and under the front lower control arms, also under the spring plates. The doors of the car will open and close as normal since as far as the chassis is concerned, this is little different that sitting normally. If I have to do front suspension work, I move the stands under the subframe as close to the suspension points as possible. If the car is lifted by the jack supports (like when I have the car on my lift), the chassis flexes and the doors are tough to open and close.
For our Spitfires, it's similar. I have stands under the frame as close to the suspension points as possible. It helps to have stands of different heights. I have (4) 3 ton stands and (4) 6-ton stands. This can help with lift point options to keep the car level.
For long-term storage (rather than service), I use dollies from Harbor Freight, in the hope they will "cradle" the tires somewhat to keep flat-spotting to a minimum.
Coincidentally, both of my cars are on stands right now...
Ian F
'78 Spit6
'73 Volvo 1800ES
(and Jerseygirl's wrench)
