Generator pully
jlaird
I note my just received generater has a much smaller pully than the other two old ones. the older ones were for a TC/TD the new one is 1969. I know the smaller one will turn faster but is this not a good thing with a generator on a street car with light use??
yes... so what is the correct diameter for a bugeye generator.
Bug pully is about 3 3/4" the late model one from Trevor is about 3".
Yep I should expect that would effect the tac, guess I best change it.
I didn't send you a pulley... /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Are you pullying his leg? /bcforum/images/%%GRAEMLIN_URL%%/lol.gif /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Noop, had a pully on the front, was a bit to small, changed to a Bugeye one, just fine.
Generator works great, light goes on and off when it should. Just came back from a trip around the block, wheeee.
Onward we go. Think the carbs are a bit lean yet, we will see. Second gear is stiff, think there must be a small burr on the detent or the detent plunger is stiff as can be yet.
Now for more bonnet work and lights and such. Gota have a bit of progress here. Two steps backward one step forward it seems.
That's the way it goes Jack.I thought I was making progress then the smoke started to escape. /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
Stuart. /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Jack, we got a snip of video from Kim, now we need to hear Miss A sing us a song! /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
