In answer to your questions, yes he replaces the armature and fields. He also guts the voltage regulator. He wants the generator sent in tact with all the internals - not sure why. Isn't the only thing I have to worry about is making sure the old pulley fits? I don't see how it will heat up if I am using the same size pulley which will make the armature spin at the same speed - can you explain this to me?
Kevin
Kevin
Hi Guest!
