The shop manual suggest 30W oil for the gearbox w/overdrive in the UK and 50W overseas at temps above 70 degrees. After checking past post I see people using Redline MT-90 and GL4 which states it's a gear oil similar to 5W40/10W40 viscosity engine oil. Some time ago I replaced the oil in the gearbox using 30W engine oil but did not check the OD operation until yesterday and it did not work. It did work prior to the oil change but I'm not sure how long prior the change. Could the oil be causing the problem or should I look elsewhere? Checked gearbox oil level a few days ago and it was correct. Actually, my first inclination is to check electrical connections. Any suggestions?
