Gearbox Latest!!!
Morris
Gearbox up-date!!!
I just finished installation of my slightly rebuilt main and input shafts. I had to tear down and reassemble the main shaft about 20 times to get it right. During one of my tear downs, I chipped 2 teeth of the first gear. Luckily, the noble and generous Jolly Roger donated an old Spitfire gearbox to the cause and I was able to extract another good first gear from it. Have you ever noticed how rust makes things really hard to take apart?
Thanks for keeping me honest guys...
Re: Gearbox up-date!!!
Rust and corrosion are a pain indeed.
*tap-tap*
YIKES! This is delicate, precision engineered English equipment!
...ohnevermind... Go-on. Wham away. /ubbthreads/images/graemlins/grin.gif
Notice ~I~ was NOT the one to do that. Coulda been, even thought about it.... odd... I took the moral high ground.
...I'll try not to let it happen again; It was a sudden lapse in judgement. I'd hate to see Jeff have to bear the burden alone. /ubbthreads/images/graemlins/devilgrin.gif
Got the tail piece on tonight.
*tap-tap*
Who says I can't learn from my mistakes.
I usually don't, but it is possible.
mehheh. "Finesse." YAY!
...sooo... when do we get a RIDE?
Soon! I will start putting the block back together tonight!
Got some FRESH PlastiGauge?
...I like th' GREEN stuff: has a "minty" flavour. /ubbthreads/images/graemlins/devilgrin.gif
Gotta go pick some up. I done run out.
Gear box is complete and ready to install!!! (and explode the first time I take the car out, I am sure)
This the first time I have ever "rebuilt" a gearbox, so I am feeling a bit insecure...
...and why does it "jingle" like that when ya tilt it? /ubbthreads/images/graemlins/jester.gif
Plug-n-play, buddy, plug-n-play!!!
[ QUOTE ]
What was that extra screw for?
[/ QUOTE ]
You don't know how true that statement is.
To finish my tran, I had to tear down and steal from another tran.
So I am standing in front of my work bench looking at the completed tran and a pile of parts and aksing myself, "was that thrust washer from the good tran or the junk one??????"
<GROAN!>
And Jim, from your earlier posts it sounds like you'll be doin' an "exploratory" on that box you've got there. Save up fast: I gotta go to th' baffroom!
