Once you learn to lift the lever it's simple...
if the shifting difficult... you should start by looking at the plastic ball at the bottom of the shift lever. They wear out and there is no telling how it might have been "repaired" in the past. Fortunately it is an easily available part and easy to replace. shifting shouldn't be stiff... Also to trouble shoot you can take off the shift lever / top plate unit from the transmission and see if the problem is in the shift lever /remote or transmission.can anybody tell me where reverse is on a 1980 1500 spitfire gear lever very stiff and cant select gears easy looked on some other forums but some say to the right and forward others saying to the left and forward ta chris
