Folks,
The starter on my 1959 3000 has finally decided to call it quits. I may rebuild it, but in the immediate time frame, I am installing a gear reduction starter.
I assume the starter does not care if the car is positive or negative ground, since there is only a single post for the battery connection. (Mine car is positive ground.)
The existing starter solenoid has a brown wire that connects to one post on the solenoid and goes to the voltage regulator.
The gear-reduction starter I bought (a Moss unit) only has one electrical post for the battery connection. Do I install the brown on this post as well?
Thanks for your help.
Ron
Ron
